19-09-2015 #27
I'll name that tune in 3 switches.!! . . . Lol (Ref to Uk Tv program called name that Tune for those out uk)
You can share the Home and Limit function using just one switch. Place that switch on the moving parts and trigger with a Target and you can bring the switches down 3 + 1 for home if slaved motor.
This is my prefered way has it saves wiring and less switches to go wrong.
Also you can have the Home Zero Position a set distance away from the physical switch trigger point. So if you want Home in the middle of the table you still can. Why you would I don't know but you can if required.
BUILD LOG: Comments sought on new build: A CNC Router for RC Gliders and Planes
By njhussey in forum DIY Router Build LogsReplies: 817Last Post: 13-04-2020, 05:03 PM -
Aluminum router build - Could use some input
By Tumblebeer in forum Gantry/Router Machines & BuildingReplies: 17Last Post: 01-09-2014, 09:48 PM -
Help appreciated
By joncdrl in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 17-09-2012, 08:34 PM
